Ik heb hem wel net voor de tune laten flushen maar goed dat werd ook wel tijd na 200.000km.Eric Beamer schreef:Heb je eerst je bak laten spoelen of staat dat los van elkaar ?
Gekocht via https://www.xhpflashtool.com/en/ ?
- Type Auto: 335i Touring
Vanaf vrijdag is xHP voor de 8-traps ZF (eerst M135i/M235i/335i/435i and 535i!) beschikbaar op Google Play:
Code: Selecteer alles
Our maps not only feature basic stuff like removing Torque Limiters and improving shift times, but they substantially change the character of the whole car.
Stage 1
The Stage 1 map takes care of everything you need to have when running an engine tune on your car. If you are plagued by the dreaded 3rd and 6th gear torque limit, but want to retain 100% stock behaviour, this is the map to go.
Stage 2
The Stage 2 map is a massive re-design and lets you access hidden shift programs and gives the driver maximum freedom of choice. We invested a lot of time in reversing the code and unlocking hidden gems. The redefined setup is now behaving similar like in M-Cars where you can freely configure the shift-speeds in 3 levels, no matter if you are in D, S or M mode. You can always select your preferred shift program and combine it with the speed and firmness you like. Off course the calibration is launch control enabled and adds features like staying in Sport-Mode, even with Traction Control turned off. Our Tip: Set your transmission in D+Sport for a totally new daily drive experience! Super-Fast but smooth, combined with an aggressive exhaust note during shifts + a bit of burbles on downshifts.
Stage 3
The Stage 3 map has all the features of the prior Stages, but adds a bit of excitemtent to your S+SportPlus mode. Put your gear lever into S and select Sport+ with the DEC switch to be ready for maximum acceleration. This mode has only goal: Maximize acceleration and shift like a racing driver would do it. If you are engaged in roll-racing or drive on a race-track, just set your transmission to S+SportPlus and it will take care of the rest and extract maximum acceleration out of your car all the time.
Vanaf vandaag dus ook voor de 8-traps ZF, om te beginnen de:
- M135i 3-Door/5-Door
- M235i Coupe/Convertible
- 335i Sedan/Touring/GT
- 435i Coupe/Convertible
- 535i Sedan/Touring/GT
- 640i Coupe/Convertible
Wie is hier de eerste met xHP voor de 8HP?
- Piet08
- Type Auto: 335d Xdrive
Ik heb begrepen dat de xHP voor de 335d in het tweede kwartaal beschikbaar komt.
Dan ben ik zeker geïnteresseerd.
- RvL
Alleen maar voor dikke auto's. Niets voor lagere x18, x20, x25 modellen e.d. Best vreemd wat daar rijden er toch echt veel meer van rond...
6hp 18d, 20d en 25i/d zijn ook maps van hoor. Maar ze zullen niet het hele gamma afdekken. De lagere motorisering is minder gericht op performance, dus die keus is ook weer niet zo vreemd.
Voor de HP8 komt er sowieso nog meer. Dir zijn de eerste modellen waar ze mee starten.
Laatst gewijzigd door Dutch79 op 27 jan 2019, 13:55, 1 keer totaal gewijzigd.
- Piet08
Ik heb ze laatst gemaild en kreeg dit terug:
Hi,
Both tools (xHP Flashtool and xDelete) are planned for late Q1/early Q2 for your car!
Regards
Hi,
Regards
- RvL
Oh mooi... toch effe in de gaten houden dan.
Wat je zegt klopt natuurlijk maar... er rijden veel VÉÉL meer getunede 16, 18 en 20 D's en I's rond dan x3x'en. Commercieel gezien had ik het toch andersom gedaan.
- JMM58
- Type Auto: BMW E92 335d
Snap eigenlijk niet zo goed wat er bij de 8HP nu zo dringend iets nodig is.
Die schakelt al snel genoeg toch..of niet?
Bij de 6 HP was dat de issue, te traag in overschakelen...is opgelost maar te traag is toch niet van toepassing bij de 8HP ?
BMW e92 335d stage 2. http://www.bmwdriversforum.nl/viewtopic.php?t=5915
Je weet pas wat je mist als je t uitprobeert. Er zal vast een merkbare verbetering zijn. We wachten de eerste ervaringen wel af.
Lees de info ff door:
viewtopic.php?f=11&t=19455&start=330#p557694
- JMM58
Ja, inderdaad toch de moeite waard, blijkbaar.
Ik sluit even aan.
Ik ben benieuwd wanneer deze voor de 116i beschikbaar komt + de prijzen ik heb soms het idee dat de bak niet helemaal weet wat hij aan het doen is, ivm de chip naar 220 pk \ 320nm ik had een keer geprobeerd om de optie sportautomaat te laten coderen alleen dit was niet gelukt, wellicht door het bouwjaar (2012)
