BartE91
Type Auto: 335i
Dutch, als het goed is kan je het voor een volgende auto ook gebruiken maar dan moet je het wel eerst van je huidige auto afhalen.
Oh, OK. Dat is de "VIN lock" die ergens genoemd werd dan vermoedelijk.
BMWcoder
Type Auto: 335i e91 '06
Ja klopt, anders kan je de app commercieel gaan inzetten zonder daarvoor extra te betalen.
Op zich wel logisch 008
General Flash License
This License enables unlimited flashing for a single vehicle. With the “General Flash
License” you can either buy and flash OTS Maps out of the xHP in-App Store, or develop
your own maps (see Chapter 2.6) and flash them to your vehicle. When purchasing
the license, xHP will lock it to the vehicle stored on the device. So before purchasing a
license, you need to connect the app one time to your vehicle and store it. The app will
ask you for that on the first connect.
Super License
The Super License works equal to the “General Flash License”, but includes all available
OTS Maps in one sweep. You will get the Flash License + Stage 1,2 and 3 Maps with a
discount, compared to purchasing the items separately. This will give you the
possibility to try all 3 Maps and switch between them as often as you like. Map
switching can be done within 2 minutes. Please note, that the Super License is not
available for all vehicles. You need to store your car onto the device, before you are
able to purchase the Super License. If the License is not available for your car, the app
will message you on purchase accordingly.
Er staat niet letterlijk dat je van auto kunt wisselen.
edit: in de FAQ wel:
Q: Is it possible to use xHP on more than one car at the same time?
A: No. You first have to uninstall xHP, before you’re able to use it on another vehicle.
Type Auto: 335d Xdrive
Kreeg vandaag antwoord op mijn mailtje.
Duidelijke taal.
Hi,
sorry, xHP currently only support 6-Speed Autos in E-Series BMW!
Regards
Clemens Richard Muehlbacher
Founder
RBT TUNING GMBH
cm@rbttuning.com
Wolfauerstrasse 19
Linz, Austria
UID: ATU65233277
FN: 464366t, Regional Court
Oh, je hebt de 8-traps ZF natuurlijk. Die is al aardig vlot toch?
Dat klopt.
Als ik zie dat het maximaal koppel bij 2300 rpm beschibaar is
had de automaat in de sportstand best iets eerder mogen schakelen.
Daarom leek me deze app zeker het proberen waard om uit te testen wat
ideaal zou zijn.
BartE91
Type Auto: 335i
BartE91 schreef:Aha, heb het net nog even nagekeken maar bij een backend kan het inderdaad niet.
Heb er gisteren nog mee gereden en dat gaat prima. Niet echt een wereld van verschil met Alpina flash naar mijn mening, maar wellicht moet de bak nog inleren of iets.
Om nog even terug te komen op mijn vorige oordeel:
De bak schakelt nu wel degelijk een stuk strakker in D, S en M ten opzichte van de Alpina flash. Vooral handmatig terug schakelen is een wereld van verschil.
Naar mijn mening is is stage 3 niet oncomfortabel. Mocht je van het schakelen niets willen voelen zou je stage 1 of 2 kunnen proberen (heb ik geen ervaring mee) maar in dat geval is de Alpina software evt ook een optie.
Met de superlicentie kun je alle stages tenminste proberen.
JMM58
Type Auto: BMW E92 335d
Is inderdaad een (dure) mogelijkheid om uit te vinden welke stage het best past maar als het snelst manueel schakelen een prioriteit heeft (Zoals in mijn geval) dan is stage 3 onoverkomelijk.
...En zoals al eerder aangegeven is stage 3 voor de D-drivers zeker ook aan te raden, gaat heel smooth.
Moet wel vermelden dat ik geen idee heb hoe de D-mode in de verschillende stages zich onderling verhoudt qua gasrespons en schakelen maar hoe meer smooth kan het zijn in stage 1&2 terwijl het stage 3 al comfortabel is.
Spollie
Type Auto: G31 LCI 530d
Goed nieuws voor de eigenaren van een N52:
xHP now supports 1 and 3-Series with N52 engine!
130i 258 HP
325i/xi 218 HP
330i/xi 258/272 HP
Zag 'm pas al in de lijst staan, maar sinds gisteren inderdaad officieel.
Ik ga 's kijken of/wanneer ik dit ga doen. Eerst 's kijken of m'n INPA-kabel geschikt is om een TCU readout mee te doen.
Spollie
Houd er wel rekening mee dat de eerste backup en flash vrij lang duren (beide ~40 minuten), dus je hebt hiervoor eigenlijk wel een externe voeding nodig.
Heb alleen n CTEK 5A. Dat zou OK moeten zijn?
Spollie
Nee, dat is een druppellader. Je hebt een voeding nodig die toch wel minimaal 30 (liever 50) ampère kan leveren op 13,8 volt. Ik heb zelf bijvoorbeeld de Maas SPS-50II, die kan 50 ampère leveren. Tijdens het flashen verbruikt mijn E60 ongeveer 25 ampère, dat ga je met een druppellader niet bijbenen.
