opties Carly app
- Type Auto: E92 335i MHD Stage 2 + Xhp stage 3.
Grappig, las net dit ook van XHP via facebook. Idd, totaal nutteloos..
Today, another post on Transmission-Adaptions, as this pops up over and over!
First, we want you to know, that xHP does NOT reset adaptions. Never. Never. Never.
We also won't implement any function to reset them, as this should be done only with good reason and not just because of an oil change or on a regular basis, like some people claim it.
Adaptions have only one purpose: Try to level shift quality over the transmissions lifetime. There is NO permanent learning whatsoever, regarding behaviour, spontanity to driver reactions or shiftpoint alteration. Sadly, this is nowadays common believe in internet forums. The source is probably material from BMW or ZF, which got interpreted wrong. Mainly because it's written from a marketing standpoint and not really a technical view. "The transmission adapts to the driver..." does sound nice and someone may interpret into this sentence, whatever sounds appealing to him. Fact is, the transmission adapts to various driving situations and uses a lot of data from the car and the drivers inputs, but that is happening real-time and does not lead to any permanent alteration of the stored maps in the TCU.
Below a screenshot from the adaption-read screen from xHP, with the important part marked read!
Dutch79 schreef:Ze geven bewust de optie om te resetten en hebben t over zelflerend. Dat klopt dus niet. Maar zoals ik hier al eerder aangaf is dat n hardnekkige misvatting. Met uitlezen is uiteraard niks mis, maar je kunt er vervolgens als consument verder vrij weinig mee.
Bij slijtage zal toch een specialist diagnose moeten stellen en evt adaptiewaarden moeten interpreteren.
xHP heeft al vaker geprobeerd om dit verhaal aan te kaarten om het beeld dat er leeft bij te stellen.
Ik gok van niet.
- Type Auto: BMW G31 540i X-Drive M-Sport
Ik kan me niet herinneren dat ik die coderingsoptie ben tegengekomen in carly.
Anders even op de website van carly kijken, daar staan alle mogelijke opties qua coderen.
BMW G31 540i X-Drive sport
Deze? Carly? Niet echt nieuw meer ofzo
Als t gebruiksvriendelijk moet zijn, nee.
Er is wel BMW-software maar die meer kan maar dan heb je n laptop nodig.
Heb mn smartphone altijd bij de hand, dus uitlezen heb ik onlangs in Frankrijk op vakantie nog gedaan. Startmotor bleek bijna dood te zijn..
Nee, heb de USB/kabelversie.
Dat is sindskort. Ik heb nog de versie waarvoor ik alleen eenmalig hoefde te betalen.
