Onthuld: F12 en F13 M6 (2012)
Hier vind je het laatste nieuws over BMW.
Daar is de sterkste uitvoering van de F12/F13/F14 6er, de M6:
BMW PressClub schreef:The new BMW M6. Coupe and Convertible.
12.02.2012
At a glance
• New edition of the BMW M6 in Coupe and Convertible body variants; generous dose of M feeling combined with alluring design aesthetics, a luxurious aura, seating for four and innovative equipment features; high-performance sports car with superior performance attributes and extremely exclusive character; BMW M6 Coupe and BMW M6 Convertible both occupy a unique position in the premium segment of the executive class thanks to their blend of outstanding dynamics, hallmark M conceptual harmony and everyday usability; further development of both concepts breaks new ground with significantly improved efficiency, optimised controls for individualising the car set-up and a wider variety of driver assistance systems and infotainment functions available from BMW ConnectedDrive.
• Visually imposing body design with dynamically elegant lines and hallmark M athleticism provides an accurate visual showcase for the car’s high-performance properties; BMW M6 Coupe with strikingly contoured roof made from carbon fibre-reinforced plastic (CFRP); BMW M6 Convertible with high-quality soft-top boasting distinctive “fin” architecture.
• High-revving 4.4-litre V8 engine with M TwinPower Turbo technology, consisting of Twin Scroll Twin Turbo technology, cross-bank exhaust manifold, High Precision Direct Petrol Injection and VALVETRONIC fully variable valve control; hallmark M power delivery headlined by instantaneous responsiveness and a sustained wave of thrust; highest output in the segment; 412 kW/560 hp at 6,000 – 7,000 rpm, maximum torque: 680 Newton metres (502 lb-ft) from 1,500 rpm; maximum engine speed: 7,200 rpm; engine output 10 per cent higher than predecessor models, maximum torque 30 per cent higher.
• Acceleration: 0–100 km/h (62 mph) in 4.2 seconds (BMW M6 Coupe) or 4.3 seconds (BMW M6 Convertible); 0–200 km/h (124 mph) in 12.6 (13.1) seconds; electronically governed top speed: 250 km/h (155 mph) or 305 km/h (189 mph) with M Driver’s Package.
• Extraordinarily fine balance between performance and fuel consumption represents major improvement on previous models; average fuel consumption in the EU test cycle: 9.9 litres per 100 km / 28.5 mpg imp (BMW M6 Coupe) and 10.3 litres per 100 km / 27.4 mpg imp (BMW M6 Convertible); Auto Start-Stop function and further Efficient Dynamics technology as standard; fuel consumption of the respective predecessor models cut by more than 30 per cent.
• Seven-speed M Double Clutch Transmission with Drivelogic; automatic gear selection tuned to deliver optimum traction, Launch Control and Low Speed Assistance; bespoke M gear selector; newly developed M leather steering wheel with gearshift paddles.
• Power sent to the rear wheels; Active M Differential ensures fully variable distribution of drive between the rear wheels. Result is optimised traction and directional stability during dynamic lane changes and when accelerating out of corners.
• High-performance characteristics with outstanding dynamics and precisely controllable handling, thanks to hallmark M harmony in the interplay of powertrain and chassis technology, aerodynamics and weight balance; weight-to-power ratio – BMW M6 Coupe: 3.3 kg/hp (7.3 lb/hp),
BMW M6 Convertible: 3.5 kg/hp (7.7 lb/hp).
• M-specific chassis with bespoke front and rear axle kinematics;
M-specific Dynamic Damper Control as standard; DSC stability control incl. M Dynamic Mode; M Servotronic steering; body strengthening using special panels; lightweight compound high-performance braking system; available as an option are newly developed, globally unique M carbon-ceramic brakes with optimum resistance to fade and wear, and lower weight.
• Engine responses, M Servotronic mapping, Drivelogic shift program,
DSC mode, damper characteristics and information shown on the Head-Up Display can be programmed individually; two M Drive buttons on the steering wheel can be used to store and call up individually configured
car set-up options.
• Body design with classical BMW Coupe/Convertible proportions, customary sporty yet elegant BMW 6 Series looks and typical M sporting edge; special M design features provide an accurate visual representation of the car’s technical profile and performance; three-section, strikingly modelled lower air intake with aerodynamically optimised flaps; new M kidney grille with black double slats; flared wheel arches; hallmark M gills with integrated direction indicator bars; aerodynamically optimised exterior mirrors and side skirts; BMW Individual High-gloss Shadow Line; exposed reflectors below the rear lights; aerodynamically optimised rear apron with diffuser between the right and left-hand pair of twin exhaust tailpipes; 19-inch (standard) or 20-inch (optional) forged M light-alloy wheels, each with a distinctive interpretation of the familiar M double-spoke design.
• Luxurious, elegantly sweeping interior design with special M controls and styling features; newly developed M double-spoke leather steering wheel; M gear selector and car set-up controls on the model-specific centre console; exclusive M sports seats with integrated belt system (optional: M multifunction seats); Merino leather upholstery with extended features; exclusive carbon-fibre interior trim strips; illuminated door sill finishers with model lettering; M-specific instrument cluster with black-panel technology; 2-zone automatic climate control with extended features, ambient lighting.
• Adaptive LED Headlights fitted as standard, extensive range of BMW ConnectedDrive features, some unmatched by any rival: BMW Head-Up Display with M-specific information, High Beam Assistant, BMW Night Vision with pedestrian recognition, Lane Change Warning, Lane Departure Warning, rear-view camera, Surround View, Speed Limit Info, internet access, extended integration of smartphones and music players, Real-Time Traffic Information and apps for receiving web radio and using Facebook and Twitter.
• Almost all BMW 6 Series equipment options available, including Comfort Access, active seats, heated steering wheel, doors with Soft Close Automatic function, Navigation system Professional, Bang & Olufsen High- End Surround Sound System.
Performance, fuel consumption and emissions data:
BMW M6 Coupe:
Acceleration [0 – 100 km/h (62 mph)]: 4.2 seconds,
acceleration [0 – 200 km/h (124 mph)]: 12.6 seconds,
top speed: 250 km/h (155 mph), 305 km/h (189 mph) with
M Driver’s Package,
average fuel consumption: 9.9 litres/100 kilometres (28.5 mpg imp),
CO2 emissions: 232 g/km, exhaust standard: EU5.
BMW M6 Convertible:
Acceleration [0 – 100 km/h (62 mph)]: 4.3 seconds,
acceleration [0 – 200 km/h (mph)]: 13.1 seconds,
top speed: 250 km/h (155 mph), 305 km/h (189 mph) with M Driver’s Package),
average fuel consumption: 10.3 litres/100 kilometres (27.4 mpg imp),
CO2 emissions: 239 g/km, exhaust standard: EU5.
BMW V8 Twin Scroll Twin Turbo (S63Tu) Engine
Displacement: 4,395cc
560hp (at 6,000-7,000rpm)
502 lb-ft torque (max torque from just 1500rpm)
Weight (coupe), unladen (DIN/EU) - 1850kg / 1925kg (4,078 / 4,243lb)
Weight (convertible), unladen (DIN/EU) - 1980kg / 2055 (4,364 / 4,530lb)
7-speed DCT transmission (manual transmission for US also likely)
Coupe average fuel consumption: 9.9 liters/100 km (28.5 mpg imperial / 23.5 US MPG)
Convertible average fuel consumption: 10.3 liters/100km (27.4 mpg imperial)
CFRP roof (carbon fiber reinforced plastic) for M6 coupe
Optional M carbon-ceramic brakes reduce weight by 19.4 kg (42.8 lb) and increase fade resistance - calipers gold-colored
Weight-to-power ratio - Coupe (3.3kg/hp, 7.3lb/hp); Convertible (3.5kg/hp, 7.7lb/hp)
Pictured colors: Sakhir Orange (coupe), San Marino Blue (convertible)
Performance:
Coupe: 0-100km (0-62mph) in 4.2 seconds (F10 M5 takes 4.4 seconds); 0-200km (0-124mph) in 12.6 seconds
Convertible: 0-100km (0-62mph) in 4.3 seconds; 0-200km (0-124mph) in 13.1 seconds
Top speed: 250kmh (155mph)
M-Drivers-Package increases top speed from 250km/h to 305km/h (155mph to 189mph)
Volledig persbericht: F13 M6 Persmap
F13 M6 Coupe:
F12 M6 Cabrio:
reymen
Type Auto: bmw e92 320i ///M sexmachine
Vette wagen maarbde achterkant oogt niet agressief genoeg
Moet zeggen dat het een heerlijk ogende auto is geworden; dat die achterkant dan niet zo agressief is hoeft ook eigenlijk niet. Zo blijft het toch een hele sportieve, doch elegante en stijlvolle verschijning als een hele snelle GT. Een sportwagen zal het toch nooit worden.
reymen
Achterlichten zijn te groot en de m6 logo in de grill heeft een sjonnie gehalte. Voorkant en de velgen ogen wel super.
Mijn hemel zeg, wat een waanzinnig mooie auto is dit geworden :In love:
wally
Type Auto: 330i
Wanneer komt hij bij de dealers? Anders moet dit in augustus onze trouwauto worden. Wat een ubergeile bak zeg.
ibinco
Type Auto: BMW I/\/\
:In love: :In love: Holly sweet mother!!! De coupe is echt een beauty!!!! :ja:
monacoblue
Type Auto: E91 320i 2006
ibinco schreef::In love: :In love: Holly sweet mother!!! De coupe is echt een beauty!!!! :ja:
+1 kwijl..kwijl............ :In love: :In love: :In love:
(OO (|||)(|||) OO)
Mich1983
Type Auto: E92 335i automaat
Kijk dit is pas lekker wakker worden :mrgreen:
Geweldige wagen zeg, alleen een beetje jammer van dat :Mpower: 6 logo in de gril.
Edje
http://www.autoweek.nl/autonieuws/18628 ... ernational" onclick="window.open(this.href);return false;
En dat interieur dan!!!
Laatst gewijzigd door Edje op 12 feb 2012, 09:42, 1 keer totaal gewijzigd.
BMW freak
Type Auto: F 32 435i
Die mogen ze hier wel op de oprit zetten, ik zal er goed passen :twisted:
Nooit harder rijden dan je beschermengel kan vliegen die van mij kan snel vliegen .
DE :Mpower: 3 Verkocht :-(
http://bmw3seriesforum.nl/viewtopic.php?f=61&t=1525" onclick="window.open(this.href);return false;
335i performance
http://bmw3seriesforum.nl/viewtopic.php?f=3&t=9863" onclick="window.open(this.href);return false;
Marc
[quote="Mich1983"]Kijk dit is pas lekker wakker worden :mrgreen:
Geweldige wagen zeg, alleen een beetje jammer van dat :Mpower: 6 logo in de gril.[/quote
Dat logo kan er gewoon vanaf, voor de rest een superauto!
LLNM4
Type Auto: M4
Net gekeken en weer niet gewonnen met de staatsloterij. :(
Deze M6 coupe is een chique bak.
laonda
Wat istie vet ! Prachtige bak weer . . . 006
Terug naar “BMW Nieuws”
