Iemand een idee mbt de meldingen die er nu (weer) in staan?
Mvg,
Bert
Spoiler
Fault Report - Carly for BMW - Version: 27.70 FV
ID1: 50f1c400-c92b-4d1e-90c1-32105784d11b-868
ID2: 41f704b4-d47d-4784-bf8e-a256acfb9149-cd0-2bfd88348f2c0c7e
INFO: 0903DDD1B3A6A0886F5E50462D2746
Base: F30
Build-Year: 2013
Faults: 8
ECUs: 18
Filter: just found
Model: 3 (F30, F31, F34, F35) Automatic engine recognition (MotorID=988, Parameter=208)
Battery: 11.9V
ADDITIONAL OBD: OFFNormal communication
Normal connection
Optimized: 84
B 2
Date: 2018-03-10 12:01:09
Carly Adapter
Version: 23
Device: >Lenovo< >LenovoTAB2A10-70F< >Lenovo TAB 2 A10-70F<
Motor Control:
Engine / Motor
ECU OK, no Fault Code
ABS / DSC / Brake:
Dynamische Stabilitäts Control / DSC
Heating / AC:
Air conditioning / Klimaanlage
PTC module: reducing heat output for Power Management
Code: 8011F9
Immobilizer System:
Body Domain Controler
Cruise Control:
Active cruise control / Aktive Geschwindigkeitsregelung
ECU not present/no response from ECU
Audio/Navi/Communication:
Infotainment
Image data invalid or malformed
Code: B7F8CB
Systems:
Front Electronic Module / Elektronik Modul Vorne
Chassis:
Steering /Lenkung
Electronic damper / Elektronische Daempfer
Body:
Automatisches Front Steering
Rear Electronics Module / Elektronik Modul hinten
FH BFH, Hall element B: Short to U_batt
Code: 03018D
FH BFH, Hall element B: Line break
Code: 03018F
FH BFH: System is not standardized
Code: 0301A0
Integrated Chassis Management Quer/Längsdynamik
Embassy error (status display driving dynamics, ID: ST DISP DRDY) - Timeout
Code: D016DC
Embassy error (status display combination, ID: ST DISP KI) - Timeout
Code: D018B5
Other:
Advanced Crash and Safety Management (ACSM)
Central Gateway / zentrales Gateway
Fuelpump-Modul (E6/PL2)
Getriebesteuerung /Transmission
Antiblockiersystem MK4 E36
Anti-Blockier-und Stability Control 5 auto. E34 / 16
Gear switch / Gangschalter
Instrument cluster / Kombiinstrument
:COMBI: System time has been reset
Code: B7F668
Advanced Telematic Module
Central Control / Zentrale Bedieneinheit
Base: F30
Build-Year: 2013
Faults: 8
ECUs: 18
Filter: just found
Battery: 11.9V
Normal connection
Optimized: 84
B 2
Carly Adapter
Version: 23
Motor Control:
Engine / Motor
ABS / DSC / Brake:
Heating / AC:
Code: 8011F9
Immobilizer System:
Cruise Control:
Infotainment
Code: B7F8CB
Systems:
Chassis:
Steering /Lenkung
Body:
Code: 03018D
Code: 03018F
Code: 0301A0
Code: D016DC
Code: D018B5
Other:
Code: B7F668
