Die zeilfunctie zal bij een snelheid tussen de 50 en 160 zelf de aandrijving ontkoppelen als de wegsituatie en omstandigheden dit toelaten met als resultaat minder brandstof verbruik.
Engelse tekst:
Thanks to new functions for the ECO PRO Mode, which can be activated via the Driving Experience Control feature, BMW is increasing the possibilities of achieving better fuel economy through intelligent energy management. From the summer of 2013, all model variants of the BMW 1 Series, the BMW 3 Series and the BMW 6 Series equipped with the eight-speed automatic transmission or the eight-speed sports transmission either optionally or as standard, will feature the new sailing mode. At speeds of between 50 and 160 km/h in the ECO PRO Mode, the drive train is disconnected as soon as the driver lifts his/her foot from the accelerator pedal without applying the brakes. As a result, the vehicle is able to ‘sail’ without engine power, thereby also achieving maximum fuel efficiency. Fuel economy is now promoted even more intensively using the optional navigation system Professional. The new anticipation assistant informs the driver of the ideal time to slow down when approaching bends, stretches, curves and roundabouts of road where speed limits are in force in order to obtain better fuel efficiency. For the first time, BMW EfficientDynamics technology and BMW ConnectedDrive technology will be networked with each other within the framework of the intelligent energy management – with the effect that further fuel savings will be achieved in ECO PRO mode.
F30 Modeljaar 2014 update vanaf 01-07-2013
- Type Auto: F20 lci 118iA Exe Sportline
.....kijk, hier hebben we wat aan!
Eigenlijk best een simpele manier van brandstof besparing....
- Dejan
Dat is Individual....zal jij wel besteld hebben Captain?
- Type Auto: F30 320dA EDE HE 2012
Vraag is hoe het systeem omgaat als je juist op de motor wil remmen bijv in drukte als je dicht op elkaar treintje rijdt. Moet je dan steeds op de rem trappen (hinderlijk voor diegene die dan achter je rijden).
Blije rijder BMW 320dA EDE HE orionsilber .
zie http://bmw3seriesforum.nl/viewtopic.php ... 30#p244780" onclick="window.open(this.href);return false;
....als ik dat geweten had mischien wel!Dejan schreef:Dat is Individual....zal jij wel besteld hebben Captain?
....neem aan dat het ook uitgeschakeld kan worden, net als het start-stop systeem.Bertje3 schreef:Vraag is hoe het systeem omgaat als je juist op de motor wil remmen bijv in drukte als je dicht op elkaar treintje rijdt. Moet je dan steeds op de rem trappen (hinderlijk voor diegene die dan achter je rijden).
Volgens mij moet je Eco-Pro helemaal niet aanzetten
- Type Auto: F30 330d
"Om gebruik te maken van de Launch Control activeert de bestuurder de DTC modus van de Driving Stability Control functie (DSC), zet hij de versnelling in de positie S en duwt gelijk de rem en het gaspedaal in. Als het rempedaal wordt losgelaten accelereert de auto zonder slip om zo optimaal gebruik te maken van het motorvermogen."Barts27 schreef:Hoe werkt de launch control bij de 8 traps sport automaat. Ik heb de 320i Touring gisteren afgeleverd gekregen.
- Type Auto: 2007-2012 BMW E90 318i HE 2012-2017 BMW F30 2.0i HE sportline. 2012-? F48 18i Msport
Je moet dan toch ook zon geblokt vlaggetje in je display zien? Zijn trouwens ook youtube filmpjes van
